Jagdtiger conversion
Hey guys Ive just seen this on ebay http://cgi.ebay.co.uk/Panzer-Jagdtig...56969937049236Any ideas if this would workas a Jagdtiger conversion using a lengthened tamiya KT chassis and running gear?
RE: Jagdtiger conversion
That is the Juckenburg static model. I'd guess you could get elevation, traverse, and recoil in there, it would just take some time to
scratch up some mounting brackets. Their resin is pretty decent stuff and is thick, so mounting brackets is not a problem. Don't know how the upper hull would match with a Tammy KT. |
1 Attachment(s)
Looks good to me. I love JTs. Brett and I often run IFA tank battles with them and the Elefants in Danville. It is a beast before which all tanks kneel. You need to own a JT at least once in your life so go for it. It is not a hard build since there is so much room inside the tank. :D
1 Attachment(s)
more Pictures of the beast, notice the length of the track with my Cain laying across it. the little blemish in the glacis , the side fender skirt used as a heat shield.
| All times are GMT -8. The time now is 01:00 PM. |
