RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Modifying main gun fire control (https://www.rcuniverse.com/forum/rc-tanks-369/10583291-modifying-main-gun-fire-control.html)
DaveBcool 06-20-2011 05:48 AM
<div style="background-color: rgb(255, 255, 255); padding-top: 5px; padding-right: 5px; padding-bottom: 5px; padding-left: 5px; margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; font-family: Arial, Verdana, sans-serif; font-size: 12px; ">Newbie here
I have a Tamiya Pershing, a Futaba 2.4 gHz 4 channel radio, and a question...
</div>How do I change the Main gun fire control to a push button on the radio instead of the default trim/stick combo?
TheBennyB 06-20-2011 09:11 AM
RE: Modifying main gun fire control
Take the back off of you TX and wire in a push button to the circuit board containing the connections off the trim pots.  You'll wanna wire/solder into the neutral position and the trim up postion wires on the circuit board.  Then you can drill a hole and postion the button on the back or shoulder of the TX.
Hope this helps.
Jeff489 06-20-2011 09:15 AM
What he said.  Here's how it's been done on Spektrum radios.  Futaba may be similar.  Firebuttons
