TIGER I LATE VERSION "WITTMANN"
1 Attachment(s)
<font size="4">TIGER I LATE VERSION "WITTMANN"
<u>NEW TIGER I AIRBRUSH LATE-VERSION METAL EDITION "WITTMANN EDITION"</u> </p> with the new metal lower hull !!</p> You can open the hull in 3 seconds ! Thanks to a brilliant closing/opening system...</p> TRACK TENSIONERS 3:1 METAL GEARBOXES The new gearboxes have one more gear (3/1) And are equipped with stronger engines (18000 u / min) All the gears are in brass bushings stored The drive axle is equipped with ball bearings THE NEW LATE PROD. METAL TRACKS COMPLETELY CLOSED TRACK LINKS THE BEST TANK WE CAN OFFER !! METAL TRACKS (WITH CORRECT CHEVERON TREADS), SMOKE SYSTEM, SOUND SYSTEM, HIGH TORQUE MOTORS, METAL SPROCKETS / IDLER WHEELS, METAL ROAD WHEELS, METAL REINFORCED SUSPENSION MOUNTING POINTS, METAL, SUSPENSION ARMS, BRASS SUSPENSION PIVOTS, METAL SPROCKET ARMOUR PLATES, METAL TURRET, METAL HEADLIGHT, METAL SPARE TRACKS ON THE TURRET, METAL SCHACKLES, and many more metal pieces... with ZIMMERIT !!!!! hand painted!! AIR BRUSHED PAINTED NEW exclusif color release WITH ZIMMERIT METAL OPENING DRIVER/MACHINE GUNNER HATCHES METAL SPROCKET + IDLER WHEELS METAL TRACKS ( LATE EDITION) METAL ROAD WHEELS Metal Sprocket Hubs Metal loader’s hatch LED MACHINE GUN METAL HATCHES (2pcs) METAL SHACKLES (4pcs) METAL TURRET VENTS (3pcs) METAL SPARE TRACK LINKS AND HOLDERS ON THE TURRET SMOKE SYSTEM METAL GEARBOXES 3:1 LATE VERSION METAL REINFORCED SUSPENSION MOUNTING POINTS METAL, SUSPENSION ARMS BRASS SUSPENSION PIVOTS, METAL SPROCKET ARMOUR PLATES SIMULATED. RECOIL ACTION FULL INDEPENDENT SUSPENSION ( new system with torsion arms!!) HI-TORQUE MOTORS MACHINE GUN SOUNDS METAL BOSCH HEADLIGHT HAND PAINTED PANZER COMMANDER METAL GRILLS ENGINE COVERS (4pcs) METAL REINFORCEMENT ON THE FRONT (2pcs) METAL COMMANDERS TURRET START/RUN/SHUT DOWN SOUNDS WORKING HEADLIGHTS METAL SPROCKET ARMOUR PLATES METAL AIR INTAKE (CORRECT SHAPE This is my first Tiger I I hope you guys Like it it cames with all extras its fenomenal</p></font> |
RE: TIGER I LATE VERSION
What sound system do you have in you tiger.
ORIGINAL: mergen What sound system do you have in you tiger. My friend the soud system is the original I think its from H/L end the RX-18 board. |
looks great....are you going to doing any weathering/wear&tear?
1 Attachment(s)
ORIGINAL: DirtyBird69 looks great....are you going to doing any weathering/wear&tear? its already AIRBRUSHend weathering I´m going to put some extras like a German zinc-bucket + metal crank arm end 200 L metal fuel oil drum end aMG 34 machine gun for the turrret |
I like it very much! Now lets' take it to the next level of WOW!!
1. Paint your spare tracks 2. Remove the Balkencruz on the turret sides 3. Paint your tools 4. Do some rust and steel dry brush on your tow cables. That will really make your little beast pop!! Don |
ORIGINAL: torpedochief I like it very much! Now lets' take it to the next level of WOW!! 1. Paint your spare tracks 2. Remove the Balkencruz on the turret sides 3. Paint your tools 4. Do some rust and steel dry brush on your tow cables. That will really make your little beast pop!! Don |
Looks great, do not add any rust. Dirt from the yard yes, but no rust on a tank that's life was measured in weeks let alone months.
To many guys want to model something that was sitting in a French field for 10 years. |
This looks great just as is and I like a more clean looking tank and I think rust/chipping has been way overdone. A little dusting or mud or with some streaking from the rain is all that's needed ... maybe.
Unless it's a diorama of a tank that's been left in a field for 10 years. ;) - Jeff |
ORIGINAL: Panther F I think rust/chipping has been way overdone. A little dusting or mud or with some streaking from the rain is all that's needed ... maybe. ;) |
I was amazed to learn how many PIV's could be built compared to the cost of a single Tiger I. In numbers they (the PIV) were better tanks.
- Jeff |
Tanks a lot to all, I´m going to paint the pair of spair tracks on the turret and get the acessories end get them painted to, maybe a little bitof rust, end I was thinking about new Decals from SS Panzer division maybe the turret number 007 Michael Wittmann tank the famous one on the last battle on Villers-Bocage.
ya i think it needs a little bit of a mud look and dusting looks kind of glossy to plus i don't think it needs two of those crosses on the side and that huge
Nice Tiger, I hope you enjoy it!
