Dmd trouble (help)
I was playing with mt tamiya Pershing today.
But suddenly whenever I tried to do full throttle, all function stopped And started again. And stop again with bit of throttle and start again. Is that a dmd controller trouble or what? Anybody has same problem? |
RE: Dmd trouble (help)
Did you check that the battery is not the cause? try that first with a different battery. If not, then try reprogramming the dmd unit.</p> |
It's the battery browning out. Try cycling the battery or replace.
Thank guys...
Sometime if you have Ni-MH battery w. 5,000mAh, you don't know when you charged your battery. I will check at home. hopefully easy fix. |
Batteries are becoming increasingly more affordable. I suggest getting a couple of new ones. that way you not only have enough on not to ruin a good day of running but you have a quick easy way of doing simple trouble shooting at the field.
| All times are GMT -8. The time now is 10:12 AM. |
