AFV Models
Seeing how I can't Ich spreche kein Deutsch (Speak German). I was wondering if someone here has purchased AFV Models Leo 2A6 idler wheels (AC-16-319) and could tell me in the universal language on how to assemble them. What I'm looking for is:
1.) How do adhere the end cap to the wheel shaft. Do I use Lock-Tite or does it lock in with pressure applied? 2.) The bolt ring the sits around the wheel shaft, do I CA glue that on? 3.) For priming the metal, could I use an automotive etching primer or Tamiya Metal Prep spray, then follow-up with NATO Green? 4.) Should I prime, paint and assemble first or assemble the complete Idler Wheel and then carry-out the priming and painting process? 5.) Is there an easier way to cut the flash of the rubber wheels? Thanks in advance for any assistance. |
RE: AFV Models
Hey There Derek<div>
</div><div>What happened to the Tiger 1? Lol!</div><div> </div><div>Sometimes the Hub caps are a tight fit other wise a tiny spot of CA! Cos you might need to take them off!</div><div>Auto etch primer is fine, I think a lot of the guys use auto primer! a lot less expensive!</div><div>I personally prime, assemble, then finish coat them if it's G<u>erman Armour!..</u> just remember not to paint over threads or contact surfaces that may need CA!</div><div>Not sure of the bolt ring? is it a washer? if it is! No glue!</div><div> </div><div>Hope this helps, I'm sure others will step in with better advice as I'm a Tank virgin! only being doing it since Xmas and on my second build!</div><div> </div><div>Cheers from bonnie Scotland</div><div>Stewart</div> |
RE: AFV Models
Hey Stewart,
The Tiger 1 is a WIP, mother has allowed me to purchase parts for it in sub sections, I'm starting off with upper hull. With the Leo 2, I bought tracks for it and it recommended the metal idler set, so I went with it. The bolt ring is more of a detail item, definitely not a washer, so it will be CA glued on. Thanks for the info mate, much appreciated. Derek |
| All times are GMT -8. The time now is 09:09 AM. |
