RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Help w/ servo elevation (https://www.rcuniverse.com/forum/rc-tanks-369/11430114-help-w-servo-elevation.html)
DaveBcool 03-03-2013 03:31 PM
This my second attempt at installing a servo for elevation in my tammy pershing...
I am using a 4ch Futaba 2.4 gHz w/ a fire button installed.
This is the sequence from the DMD to the servo.
<span class="Apple-style-span" style="font-family: 'Lucida Grande', 'Trebuchet MS', Helvetica, Arial, sans-serif; font-size: 13px; color: rgb(75, 92, 119); line-height: 18px; ">Receiver &gt; Dual Servo Extension Slot 1 &gt; Tamiya Electronics Channel 3<br style="margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; " />Dual Servo Extension Slot 2 &gt; 6" extension &gt; Servo Rate Reducer &gt; Micro servo
The elevation works fine.
The problem is when I fire, the servo "hops" a bit, enough to redirect the barrel.
I have tried to insert 1 or 2 more rate reducers in sequence.
The more I add, the less it hops when I fire.
However, with 3 rate reducers installed, the servo twitches the whole time.
Any thoughts?
<br type="_moz" /></span><br type="_moz" />
TheBennyB 03-03-2013 03:54 PM
RE: Help w/ servo elevation
Maybe a DMD/MF recalibration with the rate reducers installed?
DaveBcool 03-03-2013 06:10 PM
Thanks Brett, I'll giver a try.
NCKT 03-04-2013 01:47 PM
Also, you may not be able to get rid of the "hop/twitch" entirely, depending on which type of fire button you use. I've used the momentary toggle type (triainer switch on a futaba) and that's the worst for this problem, second worst was the "radio shack" fire button. I use the click-y type buttons for firing. They are the type discussed here in this thread:
http://www.heatarmor.com/phpbb/viewt...f=12&amp;t=689
DaveBcool 03-04-2013 03:59 PM
Yeah, I tried again today and re-set everything.
It was still a bit twitchy and jumpy.
Also, another problem arose after I took out the self centering spring on the Tx.
After I move the stick up or down 3 or 4 notches, the sound for the barrel elevation comes on and stays on.
Therefore, I cannot fire while it makes this sound.
I know guys use servos for elevation, what the hell am I doing wrong?
NCKT
I have a clicky button installed, along with a VBT (vibrating unit)
I also tried my Panther Tx, which has a Radio Shack cheap o rama momentary switch w/ no VBT.
It does the same thing.<br type="_moz" />
Jeff489 03-04-2013 06:39 PM
I've never used rate reducers on mine (done it on about 10 so far).  I have always used the Dionysis camera positioner switches.  Never had any jumps or twitches.
TheBennyB 03-04-2013 07:29 PM
Dave,
Thought you knew of the elevation noise problem. Yup, can't fire when the elevation or depression sound is going. Most guys are using 5+ channel radios and
have it mixed into different channels. To stay with a 4 channel set up you'll need to get a camera mount servo delay. It slows the servo, but also stops it in positon so you
don't have to remove the self centering stick. I learned the hard way as well. For years I was doing elevation/depression fan shots with my PZ III since I had to elevate, let go of stick, then fire before my
barrel got off target.
http://dionysusdesign.com/product_in...fabaf3ab69fdf1
<br type="_moz" />
