paint help
Hi what is a good percentage paint to thinner for an airbrush, tamiya paint& thinner. THANKS
RE: paint help
60\40 paint\thinner works for me just fine. or was it 40\60.........
RE: paint help
1 Attachment(s)
I use between 60%-70% thinner vs. 40%-30% paint when I spray Tamiya paint. For me the ratio depends on how dark the color. The paint/thinner mix should pour like milk. Here is a photo of a Tamiya Tiger II sprayed with Tamiya paints.
RE: paint help
It's really a matter of trial and error, nearly impossible to give you an accurate percentage because it depends on your airbrush, pressure and atmosphere. Humidity and room temperature has just as much to do with it as the other factors and I find myself adjusting over the course of a session. Even an older bottle will be different than a freshly cracked one.
A good starting guideline is milk like consistency as stated above and go from there. One thing to add, I've used iso alcohol as a thinner for Tamiya acrylic (they aren't water based acrylics by the way, the use ethers) for about 10 years with no issues whatsoever. Both thinning and cleaning. Some use Windex too, but I only use that with Future. There's no need to pay through the nose for Tammy thinner when you can get a quart of isopropyl for a few bucks. |
RE: paint help
You can also achieve different effects by how you mix it. The more thinner you use the faster the paint dries as it is sprayed so you can get different tones just by the mixture.
RE: paint help
THANKS for the help you can always count on this forum to help . THANKS again
RE: paint help
I'll be honest I've found Tamiya paint sprays fine with minimal to no dilution. Depends how good you want the coverage to be in one pass or your going for any effects.
| All times are GMT -8. The time now is 06:01 AM. |
