Panzer IV sound question
Does the Panzer IV with a stock MFU 5 unit have a sound when the turret moves or the main gun moves up or down ?
thanks ;);) |
RE: Panzer IV sound question
ORIGINAL: easyy 11 Does the Panzer IV with a stock MFU 5 unit have a sound when the turret moves or the main gun moves up or down ? thanks ;);) |
I can let you know for sure later today hen I install the elevation and rotation.
As it is, I didn't hear any while testing the running gear. It has MG and cannon sounds without them hooked up, so I suspect it doesn't have them. I'm not up on the mechanics of the IVs, but I did build DML's static E years ago and seem to remember a lot of hand cranks in the turret. Since they were the cheaper/quicker construction of the German armor, maybe they were manual rotation and elevation. |
The Panzer IV turret was hand cranked so the Tamiya Panzer IV should have no sound .
Jimmy |
My MF-05 doesn't have turret rotation or gun elevation sounds.
Actualy PzIV F,G and H had power assisted turret rotation the Tamiya PzIV is based on the J version this to accommodate larger fuel tanks went back to hand rotation as opposed to power assisted , gun elevation was also operated by hand this was common in tanks of the Time
Thank you guys
Mine is no elev no turn so its all working correctly . Those were the days of manual labour that is for sure Lots of Oat Flakes in the morning LOL Cheers ;) ;) |
Lots of pucker factor trying to get that damned turret around before you got your face blown off.
ORIGINAL: Panther G Lots of pucker factor trying to get that damned turret around before you got your face blown off. |
Now its all computer operated push a button and done
ORIGINAL: ausf ORIGINAL: Panther G Lots of pucker factor trying to get that damned turret around before you got your face blown off. |
