RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Leopard 2a6 elevation mod? (https://www.rcuniverse.com/forum/rc-tanks-369/11591520-leopard-2a6-elevation-mod.html)
Despotes 12-14-2013 05:15 PM
I've searched for this mod that apparently involves simply resoldering 1 wire, but can't find it here or Google.
Could someone point me in the right direction? Pics would be nice too.
cleong 12-14-2013 05:41 PM
More information would be good - are you referring to the Tamiya or Heng Long Leopard 2A6, and what do you hope to achieve with the elevation mod?
bowlman 12-14-2013 05:43 PM
There is a mod on the Clark web site on how to due it for the TK boards if thats what your looking for .
http://www.clark-model.com/eng/index_e.html
Jimmy
Forgetful_Duck 12-14-2013 06:11 PM
If you mean the mod that allows you to...
1. use the airsoft cannon synchronized with the shell / reload sound...
2. Control the elevation motor to run in BOTH directions instead of cycling through in one direction. (on a mode 2 transmitter - it's LEFT stick at 75% up from the bottom and then use left and right movement to control elevation up and down)
Then follow my guide here...
http://www.rcuniverse.com/forum/rc-t...l#post11671841
Need to reconnect (or resolder) 1 wire. Basically its a splice.
Then you need to SWAP the position of 2 other wires with each other on one of the plugs. See photo on the guide on which wires and what it should like look.
Despotes 12-14-2013 06:12 PM
Heng Long. So far, just to have proportional up and down. I'm removing the Airsoft.
I'll check out the Clark site
Forgetful_Duck 12-14-2013 06:16 PM
Either way just do what I did, it fixes it.
The TK22 site is HEAPS confusing. It took me ages to figure it out. I didn't follow the photo guide.
I looked at the control board specs for a tk22 and which wires should be connected to which pin on the main tk22 board. Then worked backwards and traced out all the wires
There's a table that displays this info. basically in stock form, some of the wires are connected to the wrong pins on the main board. SO it's just a matter of swapping the positions.
Forgetful_Duck 12-14-2013 06:25 PM
1 Attachment(s)
More specifically I used this chart and diagram...
The plugs you need to look at are CN9 and CN3 (middle column with the HL airsoft / recoil)
http://www.rcuniverse.com/forum/atta...mentid=1947580
Where it says gun elevation motor TWICE for 2 pins, it doesn't matter if its negative (-) wire or Positive (+) wire.
LED's though need to have the correct polarity to function.
