RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   KV-1 & Jadgpanther full option problems (https://www.rcuniverse.com/forum/rc-tanks-369/11595387-kv-1-jadgpanther-full-option-problems.html)
mcovalsk 02-26-2014 04:02 PM
I bought a Heng Long KV-1 and Jagdpanther with full IR option, metal gears, tracks…etc.
I realized that the standard suspension can’t support the weight of the model. I was working on the KV-1 rear suspension and got a better tension but still is very soft.
The Jagd is worst, the front doesn’t support the weight.
Somebody have had this problem and which was the way fixed it.
Thanks in advance.
cleong 02-26-2014 04:22 PM
You need Asiatam chassis upgrades:
http://www.asiatam.com/product_info....cffte1rii7epc7
http://www.asiatam.com/product_info....ngbuchsen.html
mcovalsk 02-26-2014 04:26 PM
Could you tell me something I don't know... and cheap LOL LOL
Panther G 02-26-2014 04:54 PM
They make an upgraded stronger spring set for both of those models. Each one has had the same problem. too weak a spring for the weight of the model. This is a known common problem on both.
mcovalsk 02-26-2014 04:56 PM
Ah Ok I will look for them
Thanks!!!!!!
Cruiser133 02-26-2014 06:59 PM
Did you try clocking them forward to create more tension? I used stock springs on my Lowe, which is VERY heavy. I simply drilled a new hole forward a few degrees and it worked like a charm....
MAUS45 02-26-2014 08:08 PM
Like Cruiser133 said you can try clocking the existing springs or get the stronger springs.I think rctank.de carries the stronger springs?
Captain Nemo12 02-26-2014 08:52 PM
I had the same problem when I was building my Panther, I got it from one of the newer HL production batches and the stock springs were pre-clocked from the factory. With metal tracks on, the weight increased significantly and the stock pre-clocked springs couldn't elevate the hull once they were compressed. You could experiment and tighten the stock springs until the desired force is achieved, but I'm not sure if you want to install and remove 16 interleaved roadwheels and their suspension arms over and over again! :rolleyes:
Personally I simply paid the 10 Euros and got some stronger Asiatam springs from Welshdragon.
mcovalsk 02-27-2014 05:17 AM
I realized that in the hull there are two holes for each arm, and the spring were placed in the easy one, just to make the build faster. I reclocked to the second one and the suspension improved a lot.
The springs the models provide are stronger than the regular one so I think is just a problem of setup. I will make an extra hole and try from there, if doesn’t work then will go for the Asiatam ones as you suggested.
Thanks my friend I appreciate the help and comments.
Strato50 02-27-2014 05:27 AM
Using the reclocked holes works very well. Just remember there is a limit to how far they will go; if you go too far when the spring coils up it will jam against the suspension arm and it will get stuck..!
Don't ask how I know... ;)
Also you can experiment with clocking the first and last suspension only so that the middle wheels move more with uneven ground, while the front & rear hold more weight. You might notice the tank drives better :D
mcovalsk 02-27-2014 05:53 AM
Yes you are right with the first and last, I tried with the M45 I'm building and work smoothly and realistic.
I will not ask how you know....that. I have a closet plenty of models that didn't get and ashamed me LOL LOL
By the way I'm pretty surprised of the good the KV-1 and Jadg are. Having in account I got the full options, including the IR receiver and paid US$179 they were a good deal. Metal anywhere, good quality plastic with outstanding details, I think that working a little on the gearboxes, barrel recoil and adding some PE, good light and a good painting weathering already you would get a fantastic and massive tank model. I love Tamiya but my wallet ( paying 50% tax also) said no more.
YHR 02-27-2014 06:31 AM
As others have mentioned reclocking the existing springs is the cheapest fix. I have done this many times and it works, without having to spend any money.
We hope to see pictures of these soon
