RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Help need Tamiya TU (https://www.rcuniverse.com/forum/rc-tanks-369/11596904-help-need-tamiya-tu.html)
CHIEFSONN 03-30-2014 05:29 AM
Help need Tamiya TU
I have T tamiya Tiger I with maybe the second generation trans unit, this trans unit has the brass extended shaft that secured to the main shaft by two 3mm grub screws. The question I have and I did not notice them until each unit was completely cleaned and I was returning the liquid into a holding container. There was a small flat thin washer each time that I did not see with all the grease as I separated each part for cleaning ,One shaft at a time.If some one could give me the were a bouts this washers belongs I will be grateful. I will post a picture later if needed @ this time I have the battery on charge. thank you
CHIEFSONN 03-30-2014 05:08 PM
Sorry no pictures seem there is a problem with the site,I contacted the site ,nothing yet it is Sunday will try later.
thecommander 03-30-2014 07:50 PM
1 Attachment(s)
Call me Wayne around lunchtime tomorrow ok pal. Try the club number first, then my cell. You are coming next Sunday right???
http://www.rcuniverse.com/forum/atta...mentid=1982918
ksoc 03-30-2014 10:20 PM
1 Attachment(s)
Here is an old picture to get you started.
Type 2 on the left, Type 1 on the Right. If no one else can help, I can dig a little deeper and take some more picts…..
Good luck.
sevoblast 03-30-2014 10:46 PM
If you have the brass final drive shaft extender it is a Type 1 as on the right of the photo. Unfortunately I no longer have an unmodified Type 1 nor a schematic of the trans. Hopefully someone on forum will have either a pristine transmission or the schematic.
CHIEFSONN 03-31-2014 07:21 AM
Thank you for your reply the tu that I have is the one pictured on the right. I can't get the photos to post on this site sorry. but I can send them elsewhere.
TheBennyB 03-31-2014 07:35 AM
Wayne, think I have an original set of those laying around somewhere. If I can get out to the shop I'll take a look for that spacer placement.
Jeff489 03-31-2014 07:47 AM
1 Attachment(s)
Looks like it goes right here...
http://www.rcuniverse.com/forum/atta...mentid=1982993
I double checked by looking at a new set I'm getting ready to Fleabay. Yep, the only washer in there.
Kudos to KSOC for the great photo (which I used).
J.
TheBennyB 03-31-2014 07:54 AM
1 Attachment(s)
Just took a quick look and it looks like the 2nd nylon/brass gear back towards the motor from the output shaft has a spacer between the brass bushing and gearbox frame on the inside wall.
CHIEFSONN 03-31-2014 12:38 PM
THANK YOU ALL now I can complete the rebuild.and put the Tiger back together, sea you on the 6th if weather permits Bret.
