Primer recommendations
I'm looking for a spray can type of primer that is safe for metal, styrene and other types of plastic.
Any recommendations? |
http://www.hobbylinc.com/primers-hob...-acrylic-paint
I have used the tamiya, AK and I also have used rustolyeum. |
This is one area of our hobby where you can save money, any Auto shop will sell you a spray can of primer and it will be as good as anything AK/TAMIYA et al sell,
I swap the spray head for one from a can of modelling paint to ensure the spray is finer than a truck fender would get!!, I don't know what you are painting but just in case you are not aware German Armour used a red primer. shaun |
The first thing you need to determine is if your primer is compatible with your paint. That's why a lot of guys will only use one brand for both paint and primer, you know they're gonna work together. So what brand of paint will you be using? I use Testors Model Master enamels and I've found that Rustoleum is good, but it's a little thick so sometimes I decant it and thin it for the airbrush, but if I'm careful not to get it on too thick I've gotten good results right out of the can. A lot of guys like the red oxide primer, but I kind of prefer the flat white if it's Rustoleum.
wrong thread
I usually go with Krylon ruddy brown primer located at Walmart. I'm not sure if that exact color is still available but they should have something in that or red oxide color.
I've tried Rustoleum and didn't have a great experience, it just didn't want to fully cure and stayed tacky and gummy when I sanded it. Could of been humidity, but I tried it a couple different times. |
I need to prime and paint a panther metal and plastic lower chassis with metal road wheels from rctankde and a trumpeter t34/76 plastic upper hull and turret that will be mounted on a taigen plastic and metal lower hull. I plan on using Vallejo acrylics for paint.
Dusty Hi, I always use a metal primer when working with metal parts on a build, I recommend "MR HOBBY" just brush a light covering on the metal parts, allow to dry, then spray an acrylic primer over the whole area to be painted. shaun
| All times are GMT -8. The time now is 08:59 AM. |
