Leopard 2A6 Question
1 Attachment(s)
This is the first time posting on the tank forum.I am new to tanks but have other RC vehicles.I bought 2 Leopard tanks on Ebay.Both were assembled.both in sad shape and spent some time and money to get them up to par. But the prices were good. Now the question. The first one came with a Fatuba TX and changed over to the Tamiya Attack TX. Firing the main gun I only have to use the right joystick forward and it fires and back it fires Machine gun.The second tank did not come with a TX and bought a second Tamiya Attack. Now on the second tank i have to use the right trim button forward and reverse to fire main gun and machine gun along with the Joystick How can I change the second tank to fire like the first. Thanks in advance. Tony
You have to run the setup in the DMD/MFU. Do you have the Tamiya's instructive?
Originally Posted by mcovalsk
(Post 12121035)
Be patient. There are a number of Tamiya owners on this forum, and they will be helpful
Here is the Tamiya Leopard 2A6 DMD setup instruction manual in pdf .
http://www.tamiyausa.com/images/prod...20/56020om.pdf Now I like to set my turret control stick so that full up fires main gun and full down fires machine gun . How you do this is when programming stick for gun up/down elevation you only move stick up or down 1/4 in ether direction then after setup is done moving the stick full up fires main gun moving stick up 1/4 moves gun elevation up and works the same for elevation down and machine gun . Also both my stick are self centering I like them that way . Thanks Jimmy |
Originally Posted by bowlman
(Post 12121068)
The right link is this for building and adjusting the DMD
http://www.tamiyausa.com/pdf/manuals/56020ml.pdf |
Jimmy ,Mario Thanks I got it .Jimmys instructions and Marios link it is working like the first leopard. Tony
glade it helped
Jimmy |
| All times are GMT -8. The time now is 01:24 PM. |
