Question on Clark TK22 setup
I recently bought the all metal Taigen Jagdtiger. Bought the Clark TK22 board and followed the setup procedures. Everything is in the proper place on the Clark board. The smoker does not work, I have no barrel recoil, nor barrel elevation. All other sounds and functions work properly. I put the Taigen board back in and everything worked fine. I am using the new Spektrum DXe radio with Spektrum Ar400 receiver. Any ideas?
I'm guessing the board is set to servo for the elevation and recoil. Are you aware that elevation is 3/4 up and over on the clarke?
Yes, I have tried up 3/4 and over and nothing. I will check on the need for servos to make these function work. Thanks for the heads up!
you might want to reverse the servo connections on the TK22 - I have to do it on all my installations to get everything to work.
Cheers CaptB |
Thanks, I will try that. Any idea why the smoker does not work with the board?
You have to program for your recoil and elevation. On the smoker where you plugged in the smoker did you install a switich or jumper in the smoker switch plug beside it? The smoker will not work without a switch or jumper. It also doesn't come on till you start the engine.
http://www.clark-model.com/chi/prod_rx20_tu/7.jpg |
I undid all plugs, reinstalled them and everything is working fine! I had tried this at least twice but I guess third time is the charm. Thanks for all the help guys. I was baffled as the Clark in my Panther G worked from the start. Again, thanks.
| All times are GMT -8. The time now is 10:00 PM. |
