Mato PZKW III no traverse
My poor PZKW III turret stopped traversing. Everything else works properly. The motor works (powered it with an AA cell). The circuit board has an output but it is fluctuating (.5 to 2.5 volts) on my voltmeter. Anyone had this problem before? Assuming I need a new board, does Mato use Clark boards? Is there a better one out there that will fit? Will it work with the Mato 6 channel transmitter?
First of all, what board do you use? Clark TK-22 or Heng Long? Secondly, have you checked to assure all cables are firmly inserted? Finally, if possible, remove the traverse motor and test it outside the tank. If you have spare, replace it to see if problem solved.
