RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   electronics help req (https://www.rcuniverse.com/forum/rc-tanks-369/11637183-electronics-help-req.html)
dragon245 03-07-2017 01:32 PM
building a vehicle with sponson mounted guns, I am using a clarke board and need to switch flash and recoil servo independently for each.Anyone done this before or can point me the right direction:confused:
TheBennyB 03-07-2017 02:34 PM
Off the top of my head I'm thinking Pico switches. You'd need a couple open channels on your RX though. You could Pico the hot wire for the recoil and flash seperately, then turn on/off those switches to get power to those units or shut them down.
https://www.dimensionengineering.com...cts/picoswitch
Ex_Pat_Tanker 03-07-2017 02:48 PM
The big draw back to pico switches is that they don't like to be switched on and left there for any length of time - you'd need to be careful to only have them engaged when you wanted to fire, and not have either one or the other 'on' at all times.
Option B would be to use the Turnigy light switch in place of the pico switch to control the live wire (also cheaper too)
TheBennyB 03-08-2017 04:25 AM
Was unaware of the issue on the Pico's Martin, I use them to control the lights on my r/c construction stuff and never had an issue. I leave the lights on for the entire length of a batt run time.
Ex_Pat_Tanker 03-08-2017 09:49 AM
That's what I thought, until I suggested to somebody else that he use them to control some lights - who then turned around a month or so later and complained that the relay had given up the ghost... Could have been a bad relay, could have been the idiot wielding the soldering iron, who knows? Not all relays are intended to be left on for long periods, and I concluded that this was probably the case here. At 20 quid a pop I'd certainly prefer to err on the side of caution if it was my money.
