RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Js2 control unit help. (https://www.rcuniverse.com/forum/rc-tanks-369/11643744-js2-control-unit-help.html)
Srobjets 12-23-2017 11:34 AM
Js2 unit turns on an everything sunctions. Re checked everything. Only issue is it will only rev and the tracks don’t run. I had this before on a different tank can’t remember. . How do I get it out of rev mode so it will drive?
Pcomm1.v2 12-23-2017 12:14 PM
2 Attachment(s)
How to release the electronic clutch idling mode:
On your transmitter, the forward and reverse driving trim tab is placed in the down position and then the driving stick, quickly, is moved down and then quickly released to it's center position. Put trim tab back to neutral, do not forget! Your good to go. If the image will not enlarge for you, go to the link below and scroll down to Step 3 in the Operation Manual.
JS_2 Manuals: https://www.tamiyausa.com/pdf/manuals/56035ml.pdf
John
Srobjets 12-23-2017 01:54 PM
Thanks. Got it fixed v
