RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   securing the speaker box in the tamiya leo 2a6 (https://www.rcuniverse.com/forum/rc-tanks-369/11668368-securing-speaker-box-tamiya-leo-2a6.html)
tch2000 08-15-2019 08:50 PM
question and help,why is it that no screws are securing the bottom of the speaker box? did i miss something? suggestions?
tch2000 08-15-2019 09:52 PM
Anyone.?
tomhugill 08-15-2019 10:04 PM
It should be secured with 6 screws. There are standoffs and holes in the box for them. Not sure if it's a mistake in the manual but it doesn't show screws fixing it down when the speaker box goes in. However the leo 2s I've had all.had the box.screwed in.
tch2000 08-15-2019 10:14 PM
yes. Nothing in the manual shows this. Damn. Any ideas of how to fix this?
Pics?
dingobattler 08-16-2019 02:14 AM
It gets fixed along with the top hull. The bottom has slots it goes into but is not screwed in. When you affix the top half, you screw the top hull into the speaker box, which secures it in place. Don't worry about the bottom, its more than secure even that way.
heavyaslead 08-16-2019 06:12 AM
The speaker box mounting instruction is missing from the booklet, it actually is screw fastened to the hull.
Also the supplied hardware (screws) are slightly too small for proper mounting to the hull.
I used slightly larger screws to mount properly
See item #12 here:
SEAD Southeast Armored Division - http://www.sead.us
pitstain 08-16-2019 04:08 PM
what he said ^^^^
watch my video
i just did this today
tch2000 08-16-2019 06:16 PM
Originally Posted by pitstain (Post 12544080)
what he said ^^^^
watch my video https://youtu.be/s9KwKbBAUug i just did this today
nice....thx a lot for your help....my question now is....what screws do i use?do i need to purchase aftermarket screws? and the size?
tch2000 08-16-2019 06:42 PM
See item #12 here:
is it the MB2 screws?or i need different ones?
jarndice 08-17-2019 01:02 AM
Every Tank that I have owned I have stripped everything out of the Hull except the Gearboxes and lined the Floor and the Sides of the Hull with "Velco",
I then glued "Velcro" patches to the base of the Speaker, the Smoker, the Mother Board and the Battery,
Now everything is secure and yet I can simply lift it out as and when I need to and I have a lot more space in the Hull especially with the Battery on its side attached to the inside wall of the Hull by its "Velcro" strip.
pitstain 08-18-2019 07:02 PM
The velcro is a good idea however in this case the speaker box is a structural component when using the stock ABS lower hull.
heavyaslead 08-19-2019 04:38 AM
If you read the build note, I used the next size SAE screw (from hardware store), If I recall correctly the Tamiya screw is a 1/4"L 3mm dia., so the next size up in SAE would be 3/8"L 1/8" dia.
