Jagdpanther Night vision
Does anyone know how it was attached on a Jagdpanther?
I've never seen a photograph of it being used on a JP, just on the panther.
I found out they tried it in one unit and found a painting someone did but it shows no details and was done at night.
If there aren't any pictures, I would guess it would be the same as on a Panther, at least for the commander's cupola.
The Jagdpanther does not have the same kind of commander's cupola.
Any pictures out there of a driver model even if on a Panther ?
I'm at work right now so I can't get you a link, but I just went to Google and searched "ir on WWII panther" and I got a ton of good images that showed both the mount at the driver's Vision port and on the commanders cupola.
Thanks. Yes I've seen a ton of photos with the IR on the Commander's Coppola. But have not seen a driver mounted IR scope
1 Attachment(s)
Great. Thanks!
