RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Ordering bolts (https://www.rcuniverse.com/forum/rc-tanks-369/11680254-ordering-bolts.html)
Andy918 07-03-2020 03:43 PM
Ordering bolts
Hey new here and to the hobby. I have a panzer IV and I managed to work the bolt loose that connects the drive wheel to the tank. It's lost out in the yard somewhere so I have no chance of finding it. I was curious to know if I could order new ones or what size they are. Thank you
Crius 07-03-2020 05:33 PM
Depends on the brand. Heng Long uses a 3mm and Taigen uses a 4mm hex head (or a cap screw). Pull the bolt from the other side and size it.
Zabretooth 07-03-2020 09:31 PM
Ebay would be the best place to get cheap fastners once you have it sized.
Panther F 07-04-2020 03:56 AM
ANY local hardware store has the fastener that will work. Simple, just match it with the other side (it will be a metric) and you will have extras. Use a lite type of loctite (or finger nail polish) on the threads to keep that from happening again.
Andy918 07-04-2020 04:48 AM
Ok I figured as much
Thanks for the quick replies!
Snake Wrangler 07-05-2020 02:24 AM
RC screz .. has everything you could ever want my go to
https://www.rcscrewz.com/
Crius 07-05-2020 03:43 AM
If all else fails, I have loads of those bolts and I'll send you a couple for free, but I'll need a photo of the remaining bolt to make sure I send the right one. On my PIII they use a hex head bolt because the "hub cap" is so shallow, but most tanks use a socket head cap screw. If you can't find what you need in your locale just let me know and I'll fix you right up.
And don't forget what Jeff said and use loctite next time!! ;)
Crius 07-05-2020 03:45 AM
ZT, you should check these guys out. They have most of the tiny stuff we need and they won't rape you too hard on the price.
https://www.microfasteners.com/
bowlman 07-05-2020 07:03 AM
I usually just get mine from ACE Hardware or Menards the real small stuff I order from Amazon .
Zabretooth 07-11-2020 11:30 PM
Cheers mate.
tankme 07-12-2020 11:44 AM
I second going to my local Ace Hardware. They have pretty much anything I have ever looked for even very small (under M2) metric stuff.
