RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Moving into tanks - need a little advice from the pros (https://www.rcuniverse.com/forum/rc-tanks-369/11693400-moving-into-tanks-need-little-advice-pros.html)
Skeezix4me 09-15-2021 09:34 AM
Hello all - I've been flying fixed wing RC since the mid 90ís and rotary wing since 2013. Iím now looking into getting an RC tank as they seem cool, and Iíd like to get my young kids into the RC hobby as well.
Iíve narrowed it down to 1/16th scale German Tiger 1, King Tiger, or Panther G, so my questions will be solely about these three models.
While cost isnít really a factor, Iím not trying to Ďget the cheapest thing possibleí.
It appears Torro/Taigen (Iím told they are the same thing, just different distributors) have a RTR metal versions of the three tanks Iím interested in that are totally scale, and painted.
Additionally, Iíve been told to Ďget a Tamiyaí. It appear Tamiya tanks are only available as kits that require assembly (no problem for me), and painting (not something Iím interested in doing).
-Are Tamiya tanks metal or plastic? Iím getting conflicting info on this.
-Are the Torro/Taigen metal RTR 1/16 scale solid tanks (reliable/easy to work on)?
-Is there an advantage to plastic over metal?
-Are Tamiya tanks only available as kits?
-Are parts readily available for both Torro/Taigen and Tamiya tanks?
Many thanks ahead of time!
jarndice 09-15-2021 01:06 PM
Tamiya Tanks are primarily Plastic BUT very high quality.
The Hull is Plastic sheathed Ally, The downside is the electronics are getting dated.
Taigen/Torro Tanks come with a quick release that gives easy access to the Hull interior and the Tiger 1 /2 by virtue of the available space internally makes them very easy to work on, The downside is the difference in specifications through the price range, It will pay you to give close attention to what each Tiger 1/2 is offering because there is an element of duplication,You would be rewarded by purchasing an aftermarket control board from IBU./Elmod/Clark etc as Taigen/Torro's electronics are pretty basic.
If it is your intention to work on your Tank then a Plastic/ABS Body and Turret are far better than a metal body which by the way is only available from MATO, That is because the inevitable mistakes you make while modifying you Tank can readily be invisibly filled on a Plastic/ABS Body and Turret whereas a metal body and Turret will forever carry the scars of your mistakes,
Spares for Tamiya Tanks and Taigen/Torro Tanks are readily available indeed there are more upgrades available from all manner of sources for the Tiger 1 than for any other 1/16 Tank in the whole of the hobby.,
cleong 09-15-2021 08:50 PM
-Are Tamiya tanks metal or plastic? I’m getting conflicting info on this.
The three Tamiya tanks you've cited are a hybrid of plastic and metal. Metal is used for structural parts such as hull bottom, torsion bar suspension, suspension arms, etc. In this case all three of them have plastic tracks, with the King Tiger's being particularly weak.
As pointed out above, plastic is easier to work on. Molded plastic parts have finer detail than molded metal parts. Plastic is also lighter, which taxes your electronics, drivetrain and suspension less than a heavy tank with a lot of metal parts.
They are available as XB (Expert Built) tanks, but I believe you would need to special order them and they don't come cheap, probably 2-3 times the cost of the unbuilt kit although it comes with a radio controller and battery.
Michal_Kaczorowski 09-15-2021 09:13 PM
I highly recommend both Taigen and Tamiya. As you said Taigen/Torro is mostly RTR (although you can buy Taigen as a "kit" - not painted ARTR). Tamiya kits are... kits to build yourself ;)
Parts are widely available for Taigen/Torro but for Tamiya not so much. Also Tamiya spare parts are as expencive as their kits. Some parts and details are interchangeable between manufacturers.
Most "pro" Taigen tanks have metal chassis (or at least sheet metal insert), metal wheels and tracks - see picture. Upper hull is mostly plastic which have advantages like ease of modifications, drilling, sanding etc. Turrets are mostly metal which causes some problems with the stiffness of the hull (modellers deal with this by strengthening them from the inside with sheet metal).
In general, those tanks are quite durable, but remember that they are not toys. They don't like tall grass and stones. Many of us change gearboxes and electronics for more realistic movement as stock are little too fast.
https://cimg7.ibsrv.net/gimg/www.rcu...c83f8e0524.jpg
PS. Don't bother with BB version.
sevoblast 09-16-2021 03:08 AM
Tamiya was the first, and still foremost, of 1/16 scale model tanks. Their electronics are 'plug and play' including the infra rot battle system available for all Tamiya tanks as a plug in addition. The Tamiya Protocol for Infrarot Combat is the competition standard in most of the world. Instructions are excellent and well laid out, quality of the kit parts is second to none. Spare parts and aftermarket transmissions and parts are readily available from various suppliers including in USA.
Your best source in US for Tamiya tank kits, spare parts and accessories is AAF Museum in Danville, Va. AAF Tank Museum PX The level of service and expertise available at Museum Store and at the numerous tank meets held on their massive indoor battlefield is first rate, no matter what question and/or problem you may have will be answered truthfully and completely. At the actual meets in Danville, the attendance is quite large and many of our acknowledged finest and expert tankers are at the meets and more than willing to help everyone with our hobby and the competitions.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
