Elmod app not working
Hi All
Just got my first ElMod. A fusion X . Connected up as per instructions down loaded the app and latest firmware. Installed this on a new windows 11 laptop. Got it to connect one time now nothing. Getting Disconnected scan in progress. Sounds are working and I can start up the engine but can’t get the motors to run. Tried to reset the board to get back to where you hold the reset button to set up the motors but nothing. Also tried a using the App for MacOS. The board will not take to a computer. Has anyone had this problem and is there a fix other than sending back. Regards Martin |
Hang in there mate someone will turn up who knows , could you show us a picture of your layout ?
Are you Sbus /PPM or PWM What radio and receiver ? It will be something simple . |
If the sounds work but the motors won't turn you're close I'd say.
Do the turret and elevation servo's work ? Try you tube and you'll find similar issues I'm sure. Elmod must have a FAQ page or technical tutorials out there. I know I'm not much help , have you tried to put a motor on the elmod motor output to see if it will spin ? |
| All times are GMT -8. The time now is 11:05 AM. |
