pershing
Anyone else having trouble with the idle mode not releasing on the Tamiya Pershing? Everything else works perfectly except the whole moving around thing. Would it have anything to do with the radio? I am using a futaba skysport, (at 75MHZ of course) and the only non standard setup I have tried is putting all drive functions left thumb and turret with the right.
RE: pershing
I use a momentary switch on the trim to avoid the idle engage hassle, just push the button and start driving.
Cheers Eric Scott |
RE: pershing
when you do the setup procedure, on the throttle channel, either 3 or 2, instead of pull off 100%, try 80%. then DMD will think you send 100%.
then when you flip the throttle to release to idel mode, radio give 120% signal. you should have no problem. if this dos not work, change a radiol. good luck. |
RE: pershing
How did you set that up?
| All times are GMT -8. The time now is 03:13 AM. |
