electrical problem with HL Tiger need help!
Hello to everybody from Monaco Europe
first i want to apologise for my english i just finish to repaint my HL tiger it is now a Wittman at Kursk but now i have a problem i just finish to reassemble it and all is working except the BB motor and the light who indicate the fire i think i make a mistake with the electrical system if anyone have an electrical schematic?or a link on the web? i think that you understand that i am a big zero in electrical system[:o] Best Regards to all joel http://static.flickr.com/93/281400776_96c9153f11.jpg http://static.flickr.com/85/281400771_049c00af9c.jpg |
RE: electrical problem with HL BB schooting
Good looking tank!
Check all solder points under turret.You may have broken when turret was apart. They are very poor solders from the factory and easy to break. Also, be sure your "gun safety" switch is turned "ON" |
Hello briz
i check all the solders and made some new one before changing all the wire with some more strongers i would like to know if i do the right connection if someone can tell me if on the first pictures all the connection are right it will be great for the tank it is not already finish i have to apply varnish and and an ultimate wheathering on it thanks to all joel |
RE: electrical problem with HL Tiger need help!
The power wire going into the turret should attach directly to the gun's electric motor. Judging from your custom connector, you may want to swap position on your red wires (gun motor and elevation unit motor).
| All times are GMT -8. The time now is 12:57 AM. |
