Need Pershing help
I'm going to start and overhaul my Hen Long Pershing and was hoping someone out there with a Tamiya version could measure the gun barrel length from muzzle to mantle for me please. I have heard that the hen long gun is shorter than it's supposed to be and need the length to correct it...many thanks in advance! :)
RE: Need Pershing help
I'm at work so I can't measure them But I own both and the HL is shorter.
:Dgreetings 602raf puff anwser to question on cannon barrel length on mine(tamiya) it is 73/8" inches long from end of muzzle break to end at mantle;)DAN
1 Attachment(s)
This is what I came up with
REVISED Make that 20.6375 cm (I originally converted 1.125, not 8.125) Kevin O'C <S.C.A.T.> |
8 1/8" - 2.8575 cm Something not quite right there. more like 20.8575 cm |
many thanks folks :)
I added 33mm to mine, made a custom inner barrel at 207mm in length.
| All times are GMT -8. The time now is 07:07 PM. |
