Need links!!
Hi all, does anyone have a few track links for a T-34 that aren't being used. Need 2 W/O guides and 2 W/ guides +pins (plastic). I like slack tracks and have no problems driving with them. They just require a little more care when turning.
My e-mail is dsketcher at hotmail dot com Thanks, Don |
RE: Need links!!
If you get more than you need PM me. I would like to do the same with mine. The Russians were very "slack" in maintainance and many old films I've seen shows the tracks wobbling up and down from being so loose.
RE: Need links!!
I believe each track will require two different links (link A and link B) as they don't look like each other. You can also adjust the track tensioner up front by moving the alignment pin to a different hole to move the idler wheel back, which will give you more slack.
| All times are GMT -8. The time now is 08:21 AM. |
