RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Idea For The Smoker (https://www.rcuniverse.com/forum/rc-tanks-369/5814564-idea-smoker.html)
Kabul Tanker 05-05-2007 03:23 PM
Idea For The Smoker
Well I am looking at a way to make my smoker operate proportionally to the motors.. However simply ataching it to the board where the motors are, or to the motors may cause more current draw and we all know how the HL boards do not like that.
So I have El Mod. The instructions call for the wires for the motors from the HL board go to the El Mod board and then wires from the El mod board go to the motors. Essentially I have been told that the draw of the motors is then on the El Mod Board and not the HL board.
Therefore.. If I hook up the smoker to the HL board, to the wires for the motor, the increased draw should not be as danaging because the draw of the motor is on the El Mod board and at the same time I get proportional current supply to the smoker, hopefully giving it proportional output.
DOES THIS MAKE SENSE GUYS???
KT
patpatballball8888 05-05-2007 04:10 PM
RE: Idea For The Smoker
This guy has the prototype for the proportional smoke generator. Check it out:
http://www.rcuniverse.com/forum/m_5800130/tm.htm
Glad to know there is another British Columbian tanker here.
Perry S. 05-05-2007 04:59 PM
KT,
I would set it up then measure the current flow through the various stages before I really got on it. I assume you'll have to pick either the left or right side channel. I believe the HL smoker is not unidirectional like my fan system so you should get smoke output in both forward and reverse.
I don't believe it will work because the HL smoker puts out little if any smoke below 6V. At slow-med speed and at idle you will have no smoke. When you are wide open you will have smoke. I could be wrong.
[sm=idea.gif]Here's an idea. Before you jeapordize your ElMod's I would hook up your smoker to a motor channel on your HL board but disconnect the motor. That way you wont blow the board and you can get an easy idea of the smoke output at various speeds.
pattonrocked45 05-05-2007 06:15 PM
cycle down about 3 posts on the main page where pscartozzi nailed the entire system down pat.
OttoDiesel 05-05-2007 08:55 PM
Uh, Perry ? You'll be needing a marketing manager soon . . . . . I'll be happy to do it - a 60/40 split !!! What do you say ???
Ralph
Perry S. 05-05-2007 09:04 PM
I prefer payment in Cheeto's and CO2 cartridges
pattonrocked45 05-06-2007 05:25 AM
Cheeto's yummy.
darkith 05-06-2007 01:38 PM
ORIGINAL: pscartozzi
Could you leave the heating element hooked up to the full battery voltage, and use a drive channel to power the pump motor? I'd think the response of the motor should be more proportional than the heater. If overloading the HL board was an issue, perhaps using a pair of diodes and a FET to isolate the actual power feed would work. This might even work with a fan providing the airflow.
D.
Kabul Tanker 05-06-2007 01:42 PM
Thats a GREAT idea!!!....
Kabul Tanker 05-06-2007 01:47 PM
You can use a double throw switch to control both the fan/motor and the heating element... since they will be two seperate systems...
