RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Existence doubt. (https://www.rcuniverse.com/forum/rc-tanks-369/6241109-existence-doubt.html)
oraculo 08-15-2007 09:23 AM
Existence doubt.
Hi, guys.
I am very new in the world of the RC. I see many forums in many languages, but I only understand Spanish and English (bad). In many places I see people that puts a fan inside the HL tank.
Why? Is the electronics of HL so bad?
Where and how is connected? I suppose that it is a fan of PC. Does it work well with the voltage of the tank?
Thank you.
wackywheelz 08-15-2007 11:02 AM
RE: Existence doubt.
It connects to the where positive (+) red cable connects to the circuit board coming from the battery, and the black negative (-) comes from the power switch to the circuit board.
I have done this on 2 of my tanks, one more to go. If you post a picture of the back of your circuit board, I can tell you where the fan's connections go
oraculo 08-15-2007 05:20 PM
Thanks wackywheelz. (Forgive my english). :D
I thought that the connection of the fan would be more complicated. I believe that I can connect it directly to the ignition switch without problems. My idea is to use the fan to ventilate the interior of the tank and to substitute the noisy motor of the smoke generator. I saw it in the following post:
http://www.rc-panzerketten-forum.com...?threadid=5072
Another thing: somebody knows if it possible to repair a smoke generator. I think that mine has died.
Thanks.
oraculo 08-17-2007 09:47 AM
Another thing: can somebody tell me how a smoker works and how is it inside?
Well.... My english.... I'm working in it... Excuse me.
uhu 08-17-2007 09:55 AM
http://www.girr.org/girr/tips/tips3/smoke_tips.html
From the people that knows almost everything about smoke units....not we, poor tankers.....
Regards (Saludos Oraculo)
Jose
oraculo 08-17-2007 05:00 PM
[X(][X(][X(]
Oh, my God. I don't still react. As soon as i'm understand that web I have to try to make me a smoker.
"Machote", you are my idol.
:D Saludos, Arturo.
Harquebus 08-18-2007 02:14 AM
Greetings Oraculo...
On the site that Uhu mentioned, the Heng Long smoker is very similar to the one called "AristoCraft Smoke Unit". It has a wick and some kind of cotton-like material many refer to as "batting" in the bottom of the smoke oil tank. I have opened mine up and removed all but a small portion of the batting to improve the smoke output. It works very well now and puts out a lot of smoke.
As that site suggests, the oil is indeed vaporized by a heater element, usually a wire. It is also true that the smoker will fail if it runs out of oil because it overheats. That seems to be the main reason for HL smoker failure.
Your English is fine. [sm=thumbs_up.gif]
-Harq
ORIGINAL: oraculo
oraculo 08-18-2007 09:48 AM
Thank you Harquebus, you are very kind but I know that my English is terrible. [:'(]
Batting? I don't understand what it is. Is it something similar to the glass fiber? If was cotton it would burn.
Did you open your smoker without problems? Is it difficult?
Greetings from Spain. :D
uhu 08-18-2007 10:19 AM
Hi Oraculo
Batting stands for "guata". Sort of fabric stuff. The most accurate spanish term for the item used in smoke gens would be "mecha", similar in texture to "guata" but weaved around a cotton core.
I've made tests with NiCr foam cutting wire at voltages ranging from 6V to 11.3V but the current draw was too high, best solution if you want a working smoke unit is replacing the mechanical pump with a PC fan and keep always wet the stuff at the heating element (just wet, not inmersed in smoke liquid)
Regards
Jose
