RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Source for Gear Reduction for Tamiya Pershing (https://www.rcuniverse.com/forum/rc-tanks-369/6412261-source-gear-reduction-tamiya-pershing.html)
Jeff489 09-25-2007 12:39 PM
Anyone have a source for some 3:1 gear reductions for a Tamiya Pershing with the black covered transmissions? I'm looking to slow mine down.
Dugster 09-25-2007 01:37 PM
RE: Source for Gear Reduction for Tamiya Pershing
Jeff,
You’ve got a Specktrum don’t you? Set the throttle for dual rate. High rate full throttle and the low rate the max speed you want. That way when you get 4 or 5 hits and the tank slows down you flip to the high rate and get some speed back.[sm=eek.gif][sm=rolleyes.gif]
Just kidding... :DBut you can use the dual rate or the end point adjustment to tone down max speed.
Panther F 09-25-2007 01:51 PM
Hey Jeff;
I used the long can Speed 400 motors in my M26A1.
http://i12.photobucket.com/albums/a2...9/HPIM1260.jpg
Overall speed was reduced plus it still has some speed when it's down to the last 1 or 2 hits.
HTH
Jeff
Jeff489 09-25-2007 02:05 PM
Doug, your memory is correct. I am using Spektrum, and that's a great idea! I'll investigate this tonight. I know I have that manual somewhere...
Jeff, as usual, you have a good idea. I should have known you'd have tried this first on your Persh. I bought a pair of Graupner 480's and am going to install them. I don't know the no-load rpm of the stock 380 Johnson motors, so I'm unsure of the speed after the motor upgrade. FYI, as to pinion gears, I had a hard time finding 10t 3.17mm (1/8 inch) pinion gears, but finally found some. I wish they had the set screw, but they are slip fit, secured by green loctite. I just got the loctite (had a heck of a time finding it too) I don't know how the new motors will affect the speed though.
I'll do before and after comparisons and post the results for each mod I try.
Panther F 09-25-2007 02:46 PM
If you don't mind me asking, where did you get your pinion gears at? I want to play around with my new M4A3E8 Sherman. Green Locktite can be found at any automotive parts store, and the other grades of the adhesive as well. I buy mine from AutoZone.
The Graupner's are a quality product, I have some 280 motors in my WSN T34/85 when I upgraded the electronics to Tamiya.
Let use know how it turns out!
Jeff
Jeff489 09-25-2007 02:59 PM
Jeff,
As to the gears, I got them from Hobby People, and they were helicopter gears. Here's where I found them. [link]http://www.hobbypeople.net/gallery/165340.asp#More[/link]
As the gree loctite, I could find blue and red, but not green. I tried all kinds of auto parts stores. I finally got it off of Amazon.
