Charger
Hi guys i'm new to the forum, i was curious can you use a mega 2 quick charger for the stock Heng Long battery?
RE: Charger
Hi no you can't that is a set 5 to 4 amp rate charge the hl batteries i would not charge more than 2 amps as they are not a good quality battery and they may blow... get yourself a MRC 969 super brain set your amps to 1.5 or 2 and press a button and it atomattically sets all the rest of the settings for you.
RE: Charger
How many mah and cells are the HENG LONG stock batteries?
RE: Charger
The HL batteries that come with the S&S HL tanks are 2000mah 7.2 volt nicad battery packs
RE: Charger
ORIGINAL: pzrwest The HL batteries that come with the S&S HL tanks are 2000mah 7.2 volt nicad battery packs Mato gives you the 2000 Mah and metal gears in all his tanks that is his way of getting you too buy from him. You get more for the money. |
RE: Charger
YOU DO ????? BIGMIG [:-][:-][:-]
RE: Charger
ORIGINAL: pzrwest The HL batteries that come with the S&S HL tanks are 2000mah 7.2 volt nicad battery packs Perry |
RE: Charger
on the 2 battery packs I got it says QL Ni-cd 2000mAH 7.2V so I'm assumeing they are Nicads
RE: Charger
I think Mato mostly used NiMH and went to NiCad for a while. At least I read that here somewhere.
| All times are GMT -8. The time now is 12:26 AM. |
