RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   I need help (https://www.rcuniverse.com/forum/rc-tanks-369/6727642-i-need-help.html)
YHR 12-07-2007 07:41 PM
I need help
:D Some of you have already figured that out, but seriously I ran the front drive Sproket off my Tiger(Heng Long) as I was pushing snow, and lost the screw that fastens the wheel to the drive axle. What machine size are the threads, so I can go buy another one????
WrathofWotan 12-07-2007 07:52 PM
RE: I need help
try emailing matotoys at their web site. they'll likely know.;)
j z 12-07-2007 08:11 PM
RE: I need help
They're M3X10. Standard hardware. Regards JZ
wackywheelz 12-08-2007 12:38 AM
RE: I need help
Did you have the "hubcap" in place? That'd stop the screw going anywhere...
YHR 12-08-2007 01:21 AM
RE: I need help
Blew the hubcap off and then the rest just started happening. It was dark and the snow deep. Didn't see anything wrong until it was too late.
blitzkrieg65 12-08-2007 11:15 AM
RE: I need help
You can find it in the spring time!:D:D:D
Straick7 12-08-2007 10:13 PM
RE: I need help
Try a metal detector, found plenty of missing screws and clips that way:eek:
Miggers 12-09-2007 07:46 AM
RE: I need help
Use M3x15 Allen capheads instead.
1.They're a damn sight easier to get into the sprocket on the end of an Allen key.
2.Put a spring washer and a penny washer on them(hence the extra 5mm length)and they don't come undone anymore.[>:][>:]
Miggers:D
YHR 12-09-2007 11:38 AM
RE: I need help
Thanks. I found one that worked laying around my workshop(Phillips). I will buy some allen head ones .
swathdiver 12-09-2007 01:22 PM
RE: I need help
Use some Blue Loctite too!
