T2000 ESC
Is the T2000 ESC worth buying? Also does anyone have a manual in pdf format for it? Next question what transmitter would I need to get to use this T2000 ESC
RE: T2000 ESC
Question pops up every once in a while. People says they couldnt get ch 3 and 4 to work etc if i remember correctly...
RE: T2000 ESC
No - absolutely, no.
I have one, and dispite of all help from this forum the range (to the radio) is no more than 2-3 m. Others have other problems too....' Regards Martin |
RE: T2000 ESC
Ok thanks for the info on the T2000 ESC.... will pass on it
RE: T2000 ESC
At the same time I bought one installed it in a 1/16 Abrams and used my Futaba AM radio and it had unbelievable distance, so I guess the ? is are the FM versions no good? My channel 3+4 worked fine just hooked them up to servos. But I would recomend the DMD unit not much more expensive, and the MF plugs right in!
RE: T2000 ESC
Well the T2000ESC I was referring to was an AM one and was for sale around 60$cdn
| All times are GMT -8. The time now is 11:34 AM. |
