Tiger Lost Forward Movement in one side
I'm trying to get my 2nd Tiger to go and i've lost movement forward movement on my Right side. The tank goes reverse on both sides but only works left side forward. Is This a wiring issue or a Board fault ?
I think i have soldered the the board up right but i'd like to make 100% sure it's one fault or another before i buy a replacement part. Cheers Eric |
RE: Tiger Lost Forward Movement in one side
Blown transistor or broken connection/dry joint.
One wire fell off or you blew a transistor. Open her up and take a look!
It's defo the transistor there are 4 in total 1 each for forward,backwards and so on;);)
you could always swap the wires on your motors till your new board arrives how often do you drive backwards but your controler will be backwards you catch my drift keeps you running
Here you go a list of the transistors and which one it is hope this helps
somebody did post up a replacement but I can't find it on the board next to each transistor is some white lettering Q6= left track reverse Q5= left track forward Q4= right track reverse Q3= right track forward These can be swapped out and replaced ( I Know i did it;);)) Regards Rob |
| All times are GMT -8. The time now is 09:07 PM. |
