fan for board
ok i just got my board and metal gears and i was gonna turn the board over but what do i do with on switch andwhere do i get a fan for board ...... man i was breakin in gears and one spins just as nice and the other spins just not as nice it almost sounds and feels as if somethin is grind but i cant see where oh well any way help with fan for board
RE: fan for board
You'll probably have to move the switch. I sourced my fan through Newark Electonics. They have a boat load of sizes. Mine was around 8 bucks.
Dan |
RE: fan for board
Which tank?
Are you talking about the smoker switch on the board? Simple, turn it on and cut it below the height of the heatsink. Then rig a remote on/off switch on the negative side of the smoker wire. Some guys swear buy big giant 40mm PC fans, I've had great success with Novak 25x25x10mm fans from Tower hobbies. They're pricey and pull a lot of air and haven't failed me yet. Binding? Have you taken the gearbox apart? You might want to separate the halves and spin each gear by hand to see if there is a problem with any of the bushings/bearings they ride in. Remove the pin ejector marks on the inside of the gears as they can rub and break them them in again, for hours if you have too, you want them to freely spin even with the motor attached when you're done for peak efficiency. Look up my builds for pictures and wiring diagrams with the fan, there are lots of ways to do it if you don't like mine. |
RE: fan for board
swathdiver...HI, you out there my friend... Just a quick question. I took the smoke unit out of my PZIII and since then I've lost a large amount of volume out of the speaker. It was fine to begin with after I took the smoker out, but now suffers this problem...The tank has always had light use indoors...Is this just a coincidence or did I do something fundemental that has harmed the boards ?.
Nick |
RE: fan for board
Check for loose wires and the connection to the board. Since you had to move the board to remove the smoker wiring, check to make sure the speaker wires aren't touching, chafed or loose. Other then that, I'm not sure.
| All times are GMT -8. The time now is 02:20 PM. |
