SU 85 Help Please! with gun system
The good lady has purchased me as SU 85 I need some advice
I want to fit a heng long remote system, Has anyone fitted elevation,traverse system. [sm=confused.gif] Also want to have recoil/muzzle flash again anyone have any experience. possibly using the tamiya recoil unit[sm=confused.gif] |
RE: SU 85 Help Please! with gun system
Hi dragon is it the wsn conversion kit?
or the 1/25 version? |
HI 432
its the WSN Conversion, she picked it up as rolling chassis off evilbay, just has original motors fitted, so have a blank canvas on the eletronics side. |
The main electronics are easy wackywheelz has done an excellent job on a tutorial for the boards
and you might want to check out Tanxalot's T34 build he converted an I/R T34 to standard H/LONG S+S boards not long ago and he covered a lot of new ground on that one If i find the link I'll post it up for you and my T34 build might give you some help This is Mikes build http://www.rcuniverse.com/forum/m_68...tm.htm#6890791 This is mine http://www.rcuniverse.com/forum/m_68...key_T34/tm.htm Rob |
My HL S&S into WSN guide (and others) can be found [link=http://members.iinet.net.au/~wackywheelz/]here[/link]
Thanks guys, awaiting arrival, then out with the tools.:D
| All times are GMT -8. The time now is 02:38 PM. |
