problem with radio ?
HL radio, now have 2 radio's, the trim on right stick went bad. Slot in trim slider opening up, wiper slipping all over. Anyone have good fix, can't glue because works to hold switch together, and rocks at that point.
RE: problem with radio ?
Have you tried mato to see if they have replacement parts?
You can replace the trim's variable resistor with a miniature from RadioShack, Fry's, or the like. Remove the wire from one outside lug of the original, measure the resistance from one outside lug to the other, go to your local electronics parts supplier and get a replacement with a value close to what the original is (if you go SLIGHTLY higher, you may get more granular trim control).
Find an rea inside the xmitr box where you can drill a hole and mount the replacement where you can reach the shaft from the outside withe the xmitr box closed up. It may look hokey, and you will have to readjust/check the trim each time you use the controller, but, it'll work. |
| All times are GMT -8. The time now is 03:22 PM. |
