ESC question
I'm purchaseing a TAMIYA TEU101BK Electronic Speed Control ESC for a project to convert a 1/6th Kubelwagon to rc. Do I plug the ESC into throttle control or the elevator control jack on the receiver? The ESC has forward and reverse. I'm assumeing that it would be the elevator jack on the receiver so when the stick is in the center postion the kebel will not move, push the stick forward the K goes forward and vice versa. Am I correct on this?
RE: ESC question
I think it would be throttle on all the rc trucks ive built all the esc's even the non reverse for race turnaments all were plugged into throttle on receiver my novac cycolne esc is plugged into throttle for speed control for my hpi rs4 mt truck .
thanks jimmy |
RE: ESC question
So if I plug the ESC lead into the throttle jack on the receiver how do I get reverse? do I set the trim to the top and the stick to the bottom?
RE: ESC question
Hey Harold, what did you ever do with that big Tiger that was given to you??? 1/6 scale I think...
RE: ESC question
It is sitting waiting for track need alot of money to get the track for it let alone the drive sprocket, road wheels and idler.
RE: ESC question
Are you using an airplane radio for this? (Remember that 72mhz isn't legal for ground vehicles, though 2.4ghz airplane radios are a-ok).
If you plug the ESC into the non-spring-return throttle channel, the mid-point would be "off", up would be forward, and down would be reverse. That's why a non-sprung throttle stick is annoying with a reversing ESC, as quite often it's hard to get it smoothly into the "off" position without the vehicle crawling slightly forward or backward. D. |
RE: ESC question
I know it says that it isn't for ground(cars) but we do use almost any rc unit up here in the middle of nowhere(LOL) I'm about 75 miles from the nearest place where there are rc'ers. We have maybe 3 guys in a 30 mile radius who are into anything rc and none of us are members of any rc club or association. So technically I could plug it into the elevator jack or put a centering spring on the throttle stick
RE: ESC question
Yeah, I understand. The only reason I point it out is that some people don't understand that an airplane in the sky will receive a signal *so* much better/farther than a surface car/boat/tank, so even though you're on the same channel, only the airborne RX sees the interference and crashes.
Anyways, yeah, you could plug it into the elevator jack or find a centering spring&arms for the throttle. D. |
| All times are GMT -8. The time now is 08:13 PM. |
