RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Vs Tiger 1 - remove wheels (https://www.rcuniverse.com/forum/rc-tanks-369/8453694-vs-tiger-1-remove-wheels.html)
Panzerfaust77 02-08-2009 05:42 PM
The wheels on my Tiger have become loose [:@]
Is there an easy way to tighten them? I would rather not remove them as they appear to be glued together...
A N Z A C 02-09-2009 12:36 AM
RE: Vs Tiger 1 - remove wheels
Hi Panzerfaust77
If your referring to the drive sprocket wheels on your Tiger1
Tank Zone have A Step By Step Visual Guide
http://www.tankzone.co.uk/pages/hl_upgrade_sproc.htm
You might find if you've got original plastic drive sprocket wheels
( made up of an outer & inner half section & held together with a center fixing screw)
the internal inner half section collar may be damaged or has cracked resulting in a sloppy fit under load
Roadwheels on the other hand are simply Push-Pull fit together on the axial shaft
Cheers ;)
crxsidan85 02-09-2009 12:54 AM
the vstank tiger wheels are simple no bushings just shaft on wheel as far as i know if you really wanted to fix very loose wheels the whole wheel assembly will have to be replaced.
