RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Where to get metal damper mounts for HL PZIII? (https://www.rcuniverse.com/forum/rc-tanks-369/8550067-where-get-metal-damper-mounts-hl-pziii.html)
dyeager535 03-06-2009 11:31 AM
Anyone selling these?
I anticipate moving mine, however the way the plastic return roller mounts were glued in place, I guarantee the plastic damper mounts won't come out in one piece either. :(
Anyone got a line drawing of a StuG or PZIII that is accurate as well? All the "real" pictures I can find show the dampers mounted near-perfectly vertical, which they don't on the HL.
gigantohawk 03-06-2009 02:25 PM
RE: Where to get metal damper mounts for HL PZIII?
1 Attachment(s)
This any good ? Post some pic's of your progress.
Nick.
dyeager535 03-06-2009 03:24 PM
That won't hurt, thanks! :)
I'm assuming the StuG suspension and side sheet metal is all going to be relatively the same, but I figure there is more out there on the PZIII than StuG.
I'll cut the damper mounts off as soon as I can get my hands on metal ones. The glue on this StuG is pretty bad. :(
philipat 03-07-2009 07:26 AM
The only place that I know of that might have them is asiatam.de. They have the preponderonce of the metal suspension parts for the PzIII. Wecohe has some as does Impact, but I don't think they'll have that part.
chilipiper 03-07-2009 10:39 AM
Actually Wecohe does seem to carry the mounts.. as part of their shock absorber kit [link=http://www.wecohe.de/shop/index.php?main_page=product_info&cPath=56_57&produ cts_id=284](here)[/link]. They're kind of pricey, though...
dyeager535 03-08-2009 11:53 PM
Thanks for the link. Maybe I can contact them and ask if they'd sell the mounts separately.
Interesting, doesn't look like those have any sort of mounting pins or anything, unlike the track tensioner setup I have. Not sure I trust adhesive on a flat surface to keep them in place long term when even the plastic ones are glued in place.
blitzkrieg65 03-09-2009 01:30 AM
ORIGINAL: dyeager535
If Bill does not have them try welchdragon or RCtank.de http://www.rctank.de/product_info.ph...roducts_id=379
http://www.rccommand.com/asiatam_upgrades.php
The Blitz
jom 03-09-2009 04:03 AM
1 Attachment(s)
I stuck with the plastic mounts, but reinforced them with brass tube through the mount, the damper, and the hull. I'll put a bolt through the lot to secure it. I did have to drill out the damper and mount slightly to get a nice snug fit on the tube.
That would get around the lateral location problem on the glued mounts.
(Sneaked in a picture of the StuG, it's still going ahead slowly...)
Jo
