To:Darkith-DBC info
what would be the result of using the Heng Long IR led with your system?
RE: To:Darkith-DBC info
It's been a while, but I think it'll work. Not sure about the range, you may need to start with a 22ohm resistor and work your way down slowly until you get equal range.
See the section on "IR LED" on this page: http://darkith.dyndns.org/~darkith/html/rx18.shtml D. |
thanks you, i appreciate the help. rest assured i am asking this question relative to use with your product only.
NP. If you make any progress, let me know and I'll update the info on the website for others...
D. |
| All times are GMT -8. The time now is 09:04 AM. |
