HL Light Question
I am definately a newbie to tanks, so please be easy on me.
I just upgraded my HL M26 Pershing to the RX18 board so I can get ready for some IR battles. While I was at it I upgraded the smoke to the progressive unit and installed a better speaker and cooling fan. After I had everything all hooked up and working correctly, I found out I had a plug left over that is supposed to make the rear lights come on with the fronts. (Here's the newbie question:) Where or what do I either plug or solder this to in order to get the rear lights back on? [sm=confused.gif] |
RE: HL Light Question
1 Attachment(s)
Hi
I have an RX18 Persing and the rear lights have it's own two pin socket soldered too the eight pin socket for the upper hull/turret, for the front lights. so you can solder a socket too the eight pin for the front lights or take the covers off the RX18 board and solder the rear lights too the board itself. but i think it would be easier just to solder a two pin too the eight pin for the front lights. jon |
| All times are GMT -8. The time now is 12:37 PM. |
