Question on Ceramic Grease
I,m building the M26, is the Ceramic Grease use for the GEARS.
Thanks, Bobbart |
RE: Question on Ceramic Grease
For the final drives in the gear-case? That's what Tamiya recommends and I used as well. As far as the gears in the motor gearbox I would use a plastic safe oil like 'Hob-E -Lube' that is used for railroad locomotives. I bought it at Hobbytown USA pretty cheap.
Either that, or the type Radio Shack offers that has Teflon in it. Pretty light oil that doesn't fling off as easily as other oils will and it's plastic safe, which is very important in any R/C model. You will need it to oil the motors bushings too. - Jeff |
Thanks for the information
| All times are GMT -8. The time now is 03:21 AM. |
