RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   pershing tracks????? (https://www.rcuniverse.com/forum/rc-tanks-369/9261214-pershing-tracks.html)
tankinstein 11-17-2009 07:44 PM
Hey all
I how tight should the tracks on HL Pershing br?... just had mine apart, and when I went to put it back together they were so tight Icould
barley get them together. when I pulled them tight there seemd to be a 1 link gap unless I pulled real tight, I am thinking there should
be 1 more link added. If anybody can helpit would be greatly appreciated.
Tankenstein
swathdiver 11-17-2009 07:55 PM
RE: pershing tracks?????
They're really tight when new. They'll loosen up after 10-20 hours of use.
johnmar78 11-17-2009 08:06 PM
loose or slack is what runs on my tank. Too tight or no play WILL add stress on your final diff. -damage your gears.
pattoncommander 11-17-2009 08:38 PM
Let them be a little loose. The Pershing always had a loose "dip" off the sprocket to the first return roller, especially on a hard turn. For that reason, the compensating idler was put on the M-46. Too tight and you are going to damage all moving parts, particularly the idler.
tankinstein 11-17-2009 10:48 PM
Thanks guys
added 1 link, if I lift tank up off the ground the tacks sag about 1inch, but the tank seems to run better (not so tight) is these ok??
afv 11-18-2009 04:58 AM
A pershing i bought was the same, tracks too tight and pulling the idler wheel arm out of shape so i put the spare link in and when they stretch i'll just remove it
regards Jack.
