Remote control Tx/Rx
Just wondering what a suitable replacement/upgrade Rx/tx would be for my Heng Long Panzer III?</p> |
RE: Remote control Tx/Rx
go for rx18 board or tamiya electronics
There are no Tx/Rx upgrades for HL tanks. They don't use a conventional receiver but a board. The only way to use a hobby grade Tx/ Rx on an HL tank is to use an El-mod or DBC system. And of course the Tamiya system.
anyone have links where you can buy? Isearched but have had no luck.
Phil at rctankwars has everything you need.
There are no Tx/Rx upgrades for HL tanks. For use with the stock Heng Long Smoke&Sound ESC/sound board, and standard 4-5 channel RC TX/RX (27mhz, 40mhz, 50mhz, 72mhz, 75mhz, 900mhz, 2.4ghz). Great for replacing the stock 27mhz radio with your own computer radio, and permits more tanks to battle together! |
Hi
I am using an old pair of Tamiya/Acom TR TX from my old Hilux 4X4 they work just fine in the preportional transmiter and receiver. jon |
Does the RX18 use a different radio? If one has a tank with an RX13 and another with an RX18, can one just swap crystals or does it have a different radio?
I believe the Non Smoke and Sound radios are different than the SS radios.
Hi
It's the same for the two step and preportional transmiters if you use a preportional transmiter on a two step receiver the tank acts sluggish and unresponsive it still works but when you let go of the lever the tank will still move for about a second more. |
| All times are GMT -8. The time now is 09:54 AM. |
