Turnigy servo speed regulators
Just bought some Turnigy servo speed regulators http://cgi.ebay.co.uk/Turnigy-3-Chan...item20adcd9308
Obviously I will require a double female connector to connect this to may Tamiya DMD question is does it matter which of the four male connectors I use for the in and out leeds as the instructions are very vauge |
RE: Turnigy servo speed regulators
Hi
I have not found it makes any difference at all what output you use. I also just soldered a plug onto the input terminals as I had a duff servo I cut the end off. A word of caution though. Make sure the tank is off its tracks when you test it as I nearly saw mine shoot off the edge of a large drop when I first fitted the unit. Took a wee bit of tuning to get it correct. cheers Gorehound |
| All times are GMT -8. The time now is 03:43 PM. |
