RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   help needed (https://www.rcuniverse.com/forum/rc-tanks-369/9304438-help-needed.html)
kclank 12-04-2009 08:33 PM
help needed
several months ago i purchased an electronics circuit from a german company which is one of our on-line sources. that device was designed to eliminate the hull recoil from heng long tank and a variation allowed it to also control cannon flash.
here is the problem. I either have lost or have never received the instructions to use this circuit. "AND" for the life of me i cannot remember where i purchased the da-m thing. Does anyone know what i am talking about, have instructions for set-up or know the source that i am alluding to? No prize other then my undying gratitude but i would appreciate any memory restart.
torpedochief 12-04-2009 11:11 PM
RE: help needed
If it was Elmod then Phil at RCtankswars. has oline manuals, or you can get manuals at the source
Here you go.
http://www.rctankwars.com/
http://www.el-mod.de/product_info.ph...4e95ab272b5bdb
Don
Pzjgr 12-05-2009 02:13 AM
RE: help needed
This is probably where you got it at:
http://www.tank-modellbau.de/
Go to the Zubehör-Elektronik section (left side) and it's this:
Platine ARM-02 für RX14/RX18
Endlich ist Sie da die einfache Lösung um das zurücksetzen des Panzers beim Schuss zu verhindern.
Das ARM-02 Modul verhindert das zurück setzen des Panzers beim Schuss der KwK. Achtung das ARM-02 Modul funktioniert nur mit der Heng Long Platine RX14 und RX18!!!! Die ARM-02 ist kompatibel mit dem RRZ-System von Asiatam.
Die ARM-02 kann mit wenig aufwand eingebaut werden nur 3 Lötpunkte sind zu setzen.
Kabellänge ca. 15cm. Maße der Platine 30mmx20mm.
Eine bebildeter Einbauanleitung liegt bei!
Or like torpedochief said it's the El-Mod system
kclank 12-05-2009 12:03 PM
RE: help needed
you are the man!!. i did review this vendor but the electronics section was not coming up... thanks a million
btw i have now found my original invoice and the instructions. life is good (LIG)
ORIGINAL: Pzjgr
kclank 12-05-2009 12:06 PM
RE: help needed
not el-mod but thanks for the input
