RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Help!! (https://www.rcuniverse.com/forum/rc-tanks-369/9323106-help.html)
Eli12 12-11-2009 08:21 PM
Help!!
While i was changing my board i plugged the led light wrong now i think i shorted them out how big and what to i need to do to replace the led P.S. i have a bulldog</p>
Eli12 12-11-2009 09:50 PM
RE: Help!!
ANY 1?
YHR 12-11-2009 09:55 PM
RE: Help!!
I doubt you burned up your LED.s. Unless you saw them light up and then fade to black, you probably just have the polarity wrong.
tankinstein 12-11-2009 10:01 PM
RE: Help!!
Hi Eli12
They are 6mm dia. for most all the leds on HL tanks.
I made some mods to my T26E3 Pershing puting the hull machine gun into the gun barrel. how I did this was I used a multiple pack of
6mm and 3mm leds- red, green, yellow and white. They wern't. much. Pack # 2761622 $2.99 they are pretty bright and you can trim them flat
with a flush cut nippers, just dont cut the metal wires inside or they won't. work, use a little Tamiya clear colors on the cut ends, brings the gloss
back.
Eli12 12-11-2009 10:07 PM
RE: Help!!
I plugged them into the motor slot</p>
Eli12 12-11-2009 10:19 PM
RE: Help!!
Do you think 5mm will fit the brake lights?
tankinstein 12-11-2009 10:40 PM
RE: Help!!
They will fit but they will be lose the leds in the front and rear lights are 6mm in diameter.
Eli12 12-11-2009 11:14 PM
RE: Help!!
http://www.radioshack.com/product/in...ductId=2103802
http://www.radioshack.com/product/in...ductId=2102849
which one do you think is better?
tankinstein 12-12-2009 09:07 AM
RE: Help!!
Hi Eli12
I guess they are 5mm diameter, these are the ones I used
<span style="color: #0000ff">http://www.radioshack.com/product/index.jsp?productId=2062588</span>
YHR 12-12-2009 09:26 AM
RE: Help!!
The Motor slot would have zero voltage running through it unless you tried operating the tank.
Eli12 12-12-2009 05:04 PM
RE: Help!!
yup i tried operating it
