Tamiya Leo2 help
finally joined the tamiya club with a leo 2a6 that i got for a great price
I have the radio installed and it works but I cannot figure out how to get the main gun or Coax to fire i figured out the lights and the rotating one and everything else i think i am also using a 2.4 6 channel radio in it anyone help ????? ps THIS THIS ROCKS! Update: transmitter is a Futaba 6EX 2.4GHz Fasst PPS thanks bigtony I have the manual you linked it helped me set up the basic functions |
RE: Tamiya Leo2 help
Darksheer, I think some of the guys are gonna ask you what transmitter your using in order to help you. Seems some of the Spektrums and other transmitters have "tricks" from what I've read on other posts.
http://members.iinet.net.au/~wackywh...,%2056020).pdf |
Mike, it was a pure pleasure meeting you and your wife over the weekend, I have sent a PM, I have always used analogue radios so never had any problems with them
Try PM'ing "GOREHOUND". He's got a Leo and uses the Futaba 2.4 setup. It works quite well. He programmed it himself. He's very familiar with what you are using.
Hello Darksheer
I use Futaba 6EX 2.4GHz on my Leo2A6 and had similar issues. The trick I found (similar to analog radios) is when set-up programming the gun elevation stick, do not fully extend top and bottom. I put a small spacer to limit the very top and bottom when programming to 'simulate' 100% stick travel. The Main gun Fire (full up) and Machine Gun (full down) requires 100%+ deflection. I just trick the radio into a more than 100% throw by programming slightly less than 100% throw when setting up the DMD. There may be a more sofisticated way to program the radio for this, but this simple way you do not have to use the trims. |
Hi
I replied to Darksheer but thought this might help others if they wanted to set up the 6EX. OK, lets get started on the setup. How to do each of the settings on the transmitter is in the manual so I will not go into that but rather tell you what they need set to. All the other settings apart from the ones I mention below should be at default settings for the transmitter. You need to get the transmitter set up for Mode 1. The good thing about the Futaba 6EX is it is dead easy to switch between the various modes. With the transmitter switched off hold both the Mode and Select buttons down together and switch the unit on. It will then come up with the STCK in the display. You need to set this to 1 using the +\- switch. Once 1 is selected switch the unit off again and you have set the mode. Switch it back on normally and then go through what I have put down next. The next step is to set up one of the stores on the set for your Leo as the 6EX can save up to six sets of setups all for different models – I have different ones for my trucks and helis stored on my own one. The manual shows you how to pick a store and set the name for it so I won’t go into that here. Once you have your store selected and named the next thing to do is set the dual rate settings for channels 1, 2 and 4 – channel three is the throttle so does not have this. Before you start doing this for each channel make sure that the D/R switch on the top front right of the transmitter is in the down position. Next go through channels one at a time setting them to 100% with the switch in the down position. You then need to move the switch to the up position and set each channel to 120%. The next thing I did was set the end point adjustments on channels 1 and 4 to 120% leaving the rest at 100%. The last thing that needs programmed on the handset is to set the Fail Safe to 50% - this is very important as it makes channel 3 go to the mid position which on the tank is neutral. Next step is to plug the various leads from the DMD unit into the receiver. I don’t plug them in as the manual suggests as it means that channel 3 is not the throttle and the other things are a bit mixed up when using mode 1 but wanting the drive and steering on the right hand stick. What you need to do is put the leads from the DMD into the receiver in the following order: DMD Receiver J1 -ïƒ* CH1 J2 -ïƒ* CH3 J3 -ïƒ* CH2 J4 -ïƒ* CH4 That should be you installed ready to set the DMD up. Do this according to the Tamiya manual but it is important that you set the tank up with the D|R switch on the transmitter in the down position. Once everything on the DMD is programmed you should be ready to go. When you want to fire the gun or use any of the options that would need to have the trim switch moved on a standard (old type) transmitter you can push to D/R stick up and the gun will fire, machine gun go or lights work when you move the appropriate stick. When you want to disable the features and just run the tank or turn turret then with the switch in the down position the other bits will not work (eg no gun fire etc) The added benefit of having it set up as I describe is that if your battery fails in the transmitter or the tank goes out of range then it will just go to idle as the fail safe will kick in. I hope all of this helps but if you have any other questions let me know. Cheers Gorehound |
i have both the coax and the main gun working perfectly
damn is it loud all i need to do is figure out the stabilizer as that doesnt want to tun on thank you for taking the time to help me out Darksheer |
Hi Darksheer
The stabilizer can be a bit tricky to master at first but with the D/R switch in the up position you need to move the left stick diagonally up to the left quickly. If it works you should hear a beep from the tank and it will then be working. If you don't get it quite right either the gun will fire or the orange flashing light will start flashing green. A bit of practice and it becomes a bit easier to hit the stabilizer though ;) cheers Gorehound |
hah no wonder it wouldnt work the instructions that came with it said to move the left stick left and the right stick forward
how do you get the orange light to turn on i can get the green one going now that i have it all figured out i need to recahrge all the batteries sigh cant win for trying again thanks |
Hi Darksheer
The light will turn orange (or more like red) when you put the tank in battle mode - this will also dim the headlights etc. To get the battle mode on push the left stick diagonally up to the right. As I mentioned, the headlights will not come on fully in this mode so don't panic that something is not working correctly.. cheers |
PS.
Get a spare battery, and a good quality one with a high Mah rating as with one it always runs out when you are having fun. With a second one you can bung it in and continue to have fun while the first one recharges :D cheers Gorehound |
PPS,
I forgot to mention, by moving the left stick diagonally down to the right you can switch the tank on and off from the transmitter. cheers Gorehound |
| All times are GMT -8. The time now is 01:24 AM. |
