RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Throttle Steering? (https://www.rcuniverse.com/forum/rc-tanks-369/9849622-throttle-steering.html)
BenjaminR 07-07-2010 08:36 AM
Throttle Steering?
Simple question here I'm sure, but how is throttle steering accomplished with a two channel radio?
I have a basic two channel Tx/Rx, two ESC/Motors (one for each track)
I'm not sure what is required to mix the signals to get the left/right throttle adjustments for steering. I was told a V-Tail mixer, but not sure if that's what would work or not as I've not worked with them before.
Any suggestions?<br type="_moz" />
pl_09 07-07-2010 12:22 PM
RE: Throttle Steering?
1 Attachment(s)
You do not need V-tail because you do not need one stick control to run a tank. A tank is runned more realisticly with 2 stick control like the real thing. Just connect one stick to each channel. You might like to adjust the sticks to point same direction either switching them on your ( expensive) transmitter or physical tailor- rotate the stick anchor on your cheap transmitter . Or if you are not up to conversions, just get used to controlling the tank with 90 degrees' different hand directions. However, you need an extra channel if you want a rotating turret.
Panther G 07-07-2010 06:02 PM
Very few of us run our tanks with 2 stick steering. Some do but not most. Gets very difficult while battling with 2 stick steering.
BenjaminR 07-07-2010 06:12 PM
I'm stuck with a pistol grip Tx, so need to make it work. I saw a video demo on a V-Tail mixer that looked like it will work, but won't know until I try it. I've also been told an X-Tail mixer would be best, but they are hard to find.
Panther G 07-07-2010 06:18 PM
This is a land craft frequency transmitter you are using, correct? Most of these tanks wont work with only 2 channels I think. Besides with the steering wheel on the sticks acts like 2 channels anyway does it not, one for left one for right and the trigger is a third. Oh and hey what part of Port Orange are you from. My parents lived there for 15 years. They just moved back up north here last year. I know they area well.
BenjaminR 07-07-2010 07:23 PM
ORIGINAL: Panther G
Right near City Center. Small world!
The Tx I'm using is the Traxxas TQ, it works on all of my cars and boats and is the only Tx that I have. It has a 3rd and 4th channel operated by thumb and finger. The throttle is Channel 2 (70/30) and the steering is Channel 1 (centered L/R).
<br type="_moz" />
