R/C truggy KYOSHO INFERNO ST US SPORTS 2 or CASTER RACING K8T rtr
KY
please note YOUR opinion on the two truggys.
diffent specs on both.
kyosho: INFERNO ST US SPORTS 2
Overview
When it comes to 1/8th Off-Road, Kyosho is number one in quality and design and nothing has been spared in designing this RTR Truggy.
Features:
The gear boxes have hardened steel spiral cut ring an pinion gears. What this means is we were able to get the transmission ratio corrected for the large Truggy tires without having to use a huge spur gear. This keeps the motor more centered in the car and the center diff lower to the chassis. Low and centered weight is always a good thing! The Inferno ST-US Sports is equipped with all the latest technology. It comes with a 12 model memory, LCD display, digital radio with all the adjustments you would ever want. The drive train rides on all ball bearings and the power from the super powerful GXR28 is transfered through a hardened steel clutch bell and spur gear. A high torque steering servo has been spec'd for great steering accuracy and durability. Last but not least, the body comes fully detailed and a competition rear wing is added to make this truck that much more ready for the track or the back yard!
Inferno ST 2 US Sports
New Blue 17mm Hubs - New Anodized Blue17mm wheel hubs. Now you can use all standard 17mm wheels.
World Championship Quality - The suspension features double A-arms, which is the same type of suspension used on the world's most sophisticated performance machines. It's durable so have the confidence that it's going to hold up even under extreme conditions.
150cc Fuel Tank - Longer run times are always a plus, and the Inferno ST includes a big 150cc fuel tank for run time of up to 15 minutes. The tank features a quick-fill spring loaded top, so you can refuel while the engine is running so you can race around until the sun goes down.
New Wing Mount - A new rear wing mount raises the rear wing 18mm and moves it 8mm to the rear, creating more down force for better jumping performance and improved high-speed handling and traction.
New 4.6 Big Block Engine - Powering the Inferno ST Sport 2 is a big 4.6cc (.28 c.i.) pull start engine (GXR28SG). This new engine features modifications to increase performance and value.
Full Ball Bearings - Full ball bearings throughout for maximum efficiency through the drive system.
High Performance Clutch - High performance teflon clutch shoes.
Hardened Gears - Front and rear diffs use machined, hardened steel spiral ring and pinion gears.
Perfex KT-14 - Set the end-points etc with the multifunctional Perfex 14 digital transmitter with LCD display, 12 model memory, end-point adjustment, digital sub-trim and more.
Body - Body comes complete with unique color scheme.
Hardened Components - Hardened clutch bell and spur gear standard.
Tough Truggy - Factory-assembled chassis shares the same tough characteristics and low center of gravity as the World Championship winning Inferno 777.
Tuned Muffler - Includes hand-welded manifold and tuned muffler.
Tons of Travel - Long suspension arms provide tons of travel and a super wide stance.
4WD - Shaft-driven 4WD with a long-wheelbase chassis and ultra-long suspension arms
CASTER RACING: K8t rtr
This is one serious truggy for the price. No other truggy on the market offers this level of quality at such an affordable price. All CNC`d parts rather than stamped, 2.4gig radio with EPA, GO 3 Port .28 Pull start engine, METAL GEARED STEERING SERVO w. 9kg TORQUE.
With a range of upgrades available for the RTR from the Pro kit including 2pc Engine Mounts, 16mm Big Bore Shocks, 7075 aluminium parts and more this is a buggy that will grow with you and take you from an RTR basher to a capable race machine.
All the Caster buggies and truggies are inspected in this country for radio set up so you can be sure that the transmitter trims, servo reverse and End Point Adjustment (EPA) are all set correctly.
• 2.4Ghz Radio with EPA.
• High Torque Go .28 Pull Start Engine
• 24pc Precisely Rubber Sealed Ball Bearings
• Steel Competition Diff. Bevels 20T+10T
• Durable Front CVDs
• 16mm BIG BORE Hydraulic Constant Volume Shock Absorbers with Dust Proof Boots
• ABS Dual-disc Brake
• 3-Shoe Competition Style Clutch
• Low CG,Water&Dust Proof Radio Box
• Adjustable Nylon Rear Wing
• CNC 6061-T6 Al-alloy Countersunk Chassis
• CNC 6061-T6 4mm Al-alloy Shock Towers
• CNC 6061-T6 Al-alloy Front Support Plate
• CNC 6061-T6 Al-alloy Steering Plate
• CNC 6061-T6 Al-alloy Center Diff. Mount Plate
• CNC 6061-T6 Al-alloy Radio Plate
Overview
Features:
KY
im getting caster for sure dude you can run bmx6 chassis with a little modding ive got it all planned out.....run thi rtr till it blows up (motor) then order mbx6 chassis mugen....then replace motor with picco. 21 and high quality hitec servos and longer dog bones to run the diffs.........sick idea huh?
IA
Yep, Phillips screws and all. Don't get me wrong, Kyosho does make some very nice equipment, possibly the best in the industry. However, this comparison is sort of like saying which truck should I get, Chevy or Ford? and then having people say that Chevy is better because they are thiking Silverado when it is a comparison of a Colorado in the question.
